gas pedal has a vibration in it. only occasional, not all the time.
Sep 26, 2010 at 7:42 PM
GMTECH
✓ASE Certified Mechanic
When does the vibration happen? Are you cruising along the highway, higher rpms? Do you feel a vibration in any other part of the vehicle? You may have tires that need a balance or a weak engine mount?
If you have more info about the symptom I may be of further help.
Nov 8, 2010 at 2:11 PM
