Transmission
DSG
  • BUICK LESABRE
1994 Buick LeSabre
automatic
65,000 miles
not sure of engine size
The car starts fine and runs I presume in 1st gear fine, but then when I get to about 10-15 mph, it revs very high. I don't have a tachometer but you can hear it cranking. This is a new problem, so haven't driven it much, but it did seem to clear up when I got up to about 35-45 mph, so I think something is wrong with 2nd gear. Check trans fluid and its full, but don't remember when last had it flushed.
Any idea what might be wrong, and roughly how much that will cost to fix at a garage? Thanks.
Wednesday, July 25th, 2007 AT 8:59 AM
TCCC143
  • 21 POSTS
Could be as simple as replacing the transmission filter. Without the proper pressure it won't shift properly. Also could be the torque converter. If it does not get good pressure it can slip causing high RPM's. Also check the TCC solenoid. This controls how the torque converter engages. Alot of oler model buicks have poor TCC solenoids and is an easy fix.
Thursday, November 8th, 2007 AT 7:57 PM
