how do I pull the axel to replace the bearing on a 92 buick LaSabre
Aug 19, 2007 at 6:25 AM
For a front wheel bearing, do not pull the axle. Remove the rotor, undo the three bolts, loosen the axle nut with a 30mm socket, and tap the hub off with a hammer.
The owner asked how to pull the axle to replace a bearing on a 1992 Buick LeSabre. The expert said a front wheel bearing does not require pulling the axle: remove the rotor, undo the three bolts, use a 30mm socket on the axle nut, and tap the assembly off with a hammer.
