Power Steering???
DANI
I have a 1998 buick Lesabre and it has recently started making a squealing noise anytime I pull to the left. I am assuming it is my powersteering, but I can not find my powersteering levels!!! :? I am trying to give the care to my parents, but I need to know what is causing this problem before they take it. The car only has 68000 miles on it and I take good care of it. Should I check my left brake pad also?
May 6, 2006 at 1:20 PM
NEPHEWDART
I would check the brake pads,. If you know where the power steering fluid is, the levels should either be shown through the side, or there the cap should have a stick connected to it.
Jun 5, 2006 at 12:40 PM
LSUSSEL
  • 252 POSTS
No, your issue is not the brake pads I dont think. its more then likely the power steering fluid is low. Do you know where the power steering resevior is located?
Jun 6, 2006 at 2:18 PM
