HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Lesabre
Climate Control
Air Conditioner
Not Working
A/C not blowing cold air
LUEVANOJAVIER23
MEMBER
2001 BUICK LESABRE
3.8L
V6
2WD
AUTOMATIC
175,000 MILES
A/C does not blow sufficient cold air, refrigerant is full. The compressor is working.
Saturday, July 14th, 2018 AT 9:11 PM
MECHANIC
Okay,
The low side pressure should be 20-25 pounds.
The high side pressure should be 2 times ambient temperature plus 15 %.
The receiver dryer should feel lukewarm to the touch while running.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Check those pressures and let me know the results.
Monday, March 22nd, 2021 AT 1:12 PM
Please
login
or
register
to post a reply.
Related Air Conditioner Not Working Content
1997 Buick Lesabre Does Not Blow Hot Air
Heater Problem 1997 Buick Lesabre Two Wheel Drive Automatic 150, 00 Miles I Had Someone Look At The Car, They Said It Was 1 Of 3...
Asked by
MaryJM
1997
BUICK LESABRE
VIDEO
Fix an Air Conditioning Not Working Video
Instructional repair video
GUIDE
Like any sub system in today's car a problem and be minor or a little more involved, this guide will help you find the problem and perform repairs. You can be the judge if...
A/c Not Working On 1994 Buick Lesabre
The Light For The A/c (econ) Doesn't Work Anymore For Some Odd Reason. I Thought It Could Be A Fuse But There Wasn't A Specific Spot For "a...
Asked by
kzetah44
1994
BUICK LESABRE
2000 Buick Lesabre Air Is Not Cool
Air Conditioning Problem 2000 Buick Lesabre 6 Cyl Front Wheel Drive Automatic Hot Air Coming Out Has No Leaks And Enough Freeon Bower...
Asked by
dhtuttle1
2000
BUICK LESABRE
2002 Buick Lesabre Power
I Changed The Battery. Now My Windows And Door Locks On The Passenger Side And Back And Front Won't Work The A/c Doesn't Work Either. Do...
Asked by
dzalay
2002
BUICK LESABRE
Driverside Hot But Pass Side Cold Air
I Have My Heater Set To 85 Or Anything That Blows Warm Air From The Driver Side, But It Blows Freezing Cold Air From The Passenger Side...
Asked by
flashpowercontact
1998
BUICK LESABRE
VIEW MORE
How to Find Low Side A/C Service Port
Air Conditioner - Add Refrigerant
