1997 Buick LeSabre Freeze Plug Replacement Fix
EMNEILSON
I have a '97 Buick LaSabre mileage is 97783. How hard is it to replace a freeze plug? Are there any special tools needed? The plug (hole) is easy to get to. Can i do this myself?
Nov 17, 2006 at 9:00 AM
JDL
  • 16,098 POSTS
Sorry for the late reply.
Drain the antifreeze down and dispose of properly.
There could be different type freeze plugs, the ones I usually replace aren't much of a problem, if you can get at it. I usually take a chisel or something and hit the inside of freeze plug, toward the left or right side of plug. Don't hit the block. Hopefully that will turn the freeze plug, sideways in the hole, then you grab the edge of plug with pliers or vice-grips and work the plug out. I usually use a little sealer on outside edge of new freeze plug. Start the freeze plug evenly into the hole. Then I use a socket that just fits inside the freeze plug, tap on the socket to insert freeze plug. You can use the other freeze plugs as a guide to how far to insert.
I realize this an old post. In the future hope you don't have any vehicle issues, but, if you do, keep the site in mind. They are always working to improve the site and it's free.
Have a good day.
Mar 31, 2015 at 7:34 AM
Suggested Repair
Drain and properly dispose of the coolant. If the freeze plug is accessible, drive it sideways with a chisel without striking the block, then pull it out with pliers or locking pliers. Apply sealer to the new plug, start it evenly, and tap it in with a socket that fits inside, matching the depth of the other plugs.
Conversation Summary
The owner of a 1997 Buick LeSabre with about 97,783 miles asked whether an accessible freeze plug could be replaced at home and what tools were needed. The expert said accessible plugs are usually manageable: drain the coolant, turn the old plug sideways with a chisel, extract it with pliers, then install the new plug evenly with sealer and a fitting socket.
