Buick Lesabre Thermostat Replacement
MCBJR
Engine Cooling problem
Buick Lesabre 6 cyl Front Wheel Drive Automatic 118000 miles
The Gasket & thermostat replaced now I have a very slow leak at the housing! Any SUggestions
Feb 13, 2010 at 7:32 AM
ERNEST CLARK
  • 1,730 POSTS
Whoever replaced your thermostat either didn't torque the bolts down correctly, or didn't use silicon on the housing.
You should take your car back to them and demand they fix it right.
If they don't, you can write back and I'll guide you through the procedure for replacing it yourself. (very simple)
Feb 20, 2010 at 12:38 AM
