89 lesabre A/T won't shift after CV joint replacement
MUFFIN1019
I have a 1989 Buick Le Sabre with 180,000, an automatic transmission, 3.8 ltr engine. I replace the driver side cv joint, now the transmission will only go into reverse and first gear. it will not shift out of first. I serviced the transmission with new filter and fluid but still will only shift into reverse and first. Please help.
Oct 22, 2007 at 12:27 AM
BMRFIXIT
  • 19,053 POSTS
[quote:46317322d5="muffin1019"]I have a 1989 Buick Le Sabre with 180,000, an automatic transmission, 3.8 ltr engine. I replace the driver side cv joint, now the transmission will only go into reverse and first gear. it will not shift out of first. I serviced the transmission with new filter and fluid but still will only shift into reverse and first. Please help.[/quote:46317322d5]
I CANT SEE A CONNECTION
IF ALL LINKS IN PLACE AND NOTHING OUT OF PLACE
YOU MAY NEED A TRANNY REBUILT
Oct 22, 2007 at 11:33 AM
BESTAUTOTECH
  • 15 POSTS
think its got a vacuum modulator and if they get on plugged for some reason like when you changed the cv joint it may not shift.
Oct 23, 2007 at 12:48 PM
