Sorry for the late reply.
Did you do any testing before you replaced anything. If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If spark everywhere, use a gage and check fuel pressure. Also, check for fuel injector pulse.
Did you check for applicable trouble codes. Your obd1, you should be able to check some codes, yourself. Go from there.
I realize this is an old post. You probably no longer own this vehicle. In the future hope you don't have any vehicle issues, but, if you do, keep the site in mind. They are always working to improve the site and it's free.
Have a good day.
SPONSORED LINKS
Saturday, April 4th, 2015 AT 2:55 PM
