License plate bulbs replacement
48,000 MILES • 6 CYL • FWD • AUTOMATIC
BULBOUT
Change license plate lamps (two).
Feb 9, 2009 at 3:37 AM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_04lesabrelicense1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_04lesabrelicense2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_04lesabrelicense_1.jpg
Feb 10, 2009 at 2:33 PM
LEFTYED
A friend brought his car by (2001 Buick LeSabre). He wanted me to change one of two license plate bulbs.
I could not figure out how to get to the bulb to change it. Will I have to remove the entire tail light assembly? Any ideas?
Thanks in advance.
Sep 25, 2018 at 10:48 AM (Merged)
AUTOTECH04
  • 16 POSTS
Yes you will need to removed the complete tail light assembly! If you move the trunk interior trim away from the trunk striker from one end to the other there is some plastic retaining nuts holding it in place. Once removed it should come right out with a little work.
I hope this helps you!
LEFTYED
I think I failed to mention that the tail light assembly is in the trunk lid. Is the striker the latch?
Thanks again.
AUTOTECH04
  • 16 POSTS
The same applies to the trunk lid. There is about seven or eight retaining nuts holding it on. Remove them and it should just pop out.
KBGOLFNUT
There are seven, number 10 nuts in side on the trunk lid. After you take those out the tail light assembly will pull out. Half a turn plastic socket will come out. Just changed mine last week, about a fifteen minute job. Hope this helps. Kenny
BILLC58
I'm having trouble getting to the bulbs to replace them. Does the entire brake/signal/backup light panel have to be removed to access the license plate bulbs?
Dec 28, 2020 at 5:33 AM (Merged)
  • 110,248 POSTS
Hi:
f you have no access from the lens or the trunk, you will need to remove the assembly. I believe the bolts are accessable throught the trunk (10mm I believe).
Let me know if this helps.
