2004 Buick Lesabre Instrament Cluster
JRDETWILER
Electrical problem
2004 Buick Lesabre 6 cyl Two Wheel Drive Automatic
Tach. Speedomiter and gas gauge are screwed up - Need to know how to remove the panel and replace it.
Dec 20, 2008 at 6:58 AM
  • 110,248 POSTS
Hi:
Are you sure they are bad and it's not another problem? Have you tried resetting the BCM? Disconnect the battery for 5+ minutes and see if that helps. Also, you may want to have the BCM tested.
Other than that, the gauges are part of an assembly cluster. You need to remove the trim around the cluster to gain access to the mounting hardware.
Dec 24, 2008 at 11:26 AM
