2004 Buick Lesabre coolant overflows and heater inop
2004 BUICK LESABRE
PUNKIZZY21
Heater problem
2004 Buick Lesabre 6 cyl Two Wheel Drive Automatic
i have been tring to track this down for almost a week now and this is the problem. first off i was driving down the road when i noted that the engine was acting sluggish and the heater was not as hot. not five min later the the engine sounded to be chocking as i applied gas and then shut off. the coolant temp gauge still showed normal thru the whole thing. some how i lost almost all the coolant so i refiled it and limped it home where i noted smoke from the exaust. i put leak stop in it and no more smoke. next day after i put bout 70 miles on it and noted that the heater was not working and the coolant gauge was climbing. i stoped and refiled the system and heat returned and i made it home. i hav since replaced the thermostat and fixed all leaks. now when i fill the system up and run the vehicle it the coolant overflow tank fills beyond its max and starts to dump out the fluid and the heater does not work at all now. i have checked with radiator pressure gauges that the system has no leaks. i am concerned that the coolant gauge might malfunction again and i end up with more damage than i can afford
Dec 20, 2009 at 8:47 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model the custom or limited and what is your engine size in liter?
What was the color of the smoke coming out of the exhaust?
Is the upper and lower radiator hose both the same temp at operating temperature.
Dec 20, 2009 at 10:22 AM
PUNKIZZY21
the smoke was white and it is a custom 3800 3.8l and the hoses feel the same the upper might be a little hotter but very marginaly
Dec 21, 2009 at 6:54 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info.
If you had white smoke it is possible you have a blown head gasket. The coolant loss is the coolant being burnt in the cylinders.
http://www.2carpros.com/topics/engine-mechanical/head-gasket
Also – try pulling a couple of spark plugs and see if you see moisture or even water in the cylinders.
With the car at normal operating temperature, please turn the heater on high and feel both heater hoses going into the firewall and see if both are hot or one is hot and one is cooler.
Dec 21, 2009 at 12:32 PM
