brake warning light
2004 BUICK LESABRE
58,000 MILES • 6 CYL • FWD • AUTOMATIC
HAMMACKL
Not every time, but quite often, when we turn a corner in either direction, the brake light comes on. Most of the time it will go out after I get above 40 mph and other times it stays on until it is parked a while.
I have not had any brake work done to this car. What can be causing the light to keep coming on?
Feb 17, 2010 at 2:54 AM
ERNEST CLARK
  • 1,730 POSTS
There's a "Brake Switch" under you dash and connected to the brake pedal where the lever is hinged at the top.
Sometimes these go bad and need replacing. Have it checked.
Feb 19, 2010 at 11:39 PM
