2004 Buick Lesabre brack replacement
THOMAS234
Brakes problem
2004 Buick Lesabre 6 cyl Front Wheel Drive Automatic
Does the hub have to be removed in order to remove the rotor ? If so, does the nut have to be replaced? Also does the hub have to be torqued, and does the calipher nuts have to be torqued? If so, would you please provide the specs. ? THANKS
Sep 11, 2010 at 2:39 AM
WRENCHTECH
  • 20,758 POSTS
No, the rotor slides right off the hub after the caliper and bracket are removed. If it's stuck around the hub, apply some penetrating oil and use a heavy hammer to jar it loose.
Sep 11, 2010 at 4:21 AM
