1988 Buick Lesabre HOW TO REMOVE THE WHEEL HUBS
SHAJODIE
Drive Train Axles Bearings problem
1988 Buick Lesabre 6 cyl Front Wheel Drive Automatic
WE CANT FIGURE OUT HOW TO REMOVE THE WHEEL HUBS WE ARE TRYING TO REPLACE A HIGH VELOCITY SHAFT what bolts are u talk ing A bout
Apr 12, 2008 at 8:14 AM
SERVICE WRITER
  • 9,123 POSTS
Pull the bolt out from behind and either use a puller to get it off the shaft, or rap the axle with a hammer to dis lodge it. The bearing may be somewhat corrodded into the spindle and you can start a couple bolts back in and strike them to force it out.
Apr 13, 2008 at 2:40 AM
