2003 Buick Lesabre Wipers work somtimes
2003 BUICK LESABRE
95,000 MILES • 6 CYL • FWD • AUTOMATIC
FIXMYCAR1
I am experiencing wipers that come on when they want to. They don't come on immediately when I switch them on. While I'm driving then they may come on 20 minutes later. I can't control them when I really need them to come on. Is this an electrical problem.
Oct 16, 2009 at 3:49 AM
  • 110,244 POSTS
When they work, use a test light or volt meter to see if the motor (under the hood) is getting power. IF it is, try running a new ground wire from the motor to a good ground on the engine, battery...
If that doesn't help and you are getting power and it still doesn't work, replace the motor.
Nov 4, 2009 at 5:21 AM
