2003 Buick Lesabre Sounds like a fan running
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
HOLCOMD
There is a noise that starts at about 35mph and getting increasingly louder with speed. The noise sounds like a fan running. The noise is does not change when the transmission is put into neutral. The noise occurs only when the vehicle is moving and does not occur when the engine rpm is changed in neutral.
The vehicle has new tires.
Dec 11, 2009 at 2:23 PM
DENNYP
  • 1,824 POSTS
Does the noise change if you steer side to side? If so, you have a bad hub assembly.
Dec 16, 2009 at 8:32 AM
