2003 Buick LeSabre Limited daytime running lights/sensor
THAIS
I have a 2003 Buick LeSabre Limited, V6, 105,000 Km. The daytime running lights do not operate. When I turn the car on all the outside lights go on and stay on whether it's light or dark outside. The headlight switch is new. Is the problem likely to be in the light sensor on the dash or in the daytime running lights relay? if it's the sensor, how easy is it to replace?
Thanks!
Apr 11, 2007 at 2:01 AM
2CARPRO JACK
  • 11,533 POSTS
You may be on to something with the light sensor.Pretty sure you lower the glove box and it is right in the top of dash, pop out, pop in
Apr 12, 2007 at 12:59 AM
THAIS
[quote:5f3bcdb276="2CarPro Jack"]You may be on to something with the light sensor.Pretty sure you lower the glove box and it is right in the top of dash, pop out, pop in[/quote:5f3bcdb276]
I tried that and unfortunately there is no access to the top of the dash. Any other suggestions?
Thanks a lot for any help you can give.
Apr 15, 2007 at 1:20 AM
