2002 Buick Lesabre Rough Shift
115,000 MILES • 6 CYL • FWD • AUTOMATIC
WILDCATIII4266
Fairly frequently the shift on the transmission is shifting with a thud or very roughly. I have read that it could be the pressure regulator selenoid. Is this most likely the problem and where is this located. I had the fluid and filter changed last month. I have checked for codes but it shows none
Feb 20, 2010 at 8:23 AM
DENNYP
  • 1,824 POSTS
If you have the codes checked with a Tech2 scan tool, you will probably find a dtc P1811. This could be caused from a bad pressure regulator solenoid, sticking regulator valve, bad pressure switch, or overall wear of internal transmission components.
The pressure solenoid is located on the valve body under the side transmission cover.
Feb 24, 2010 at 3:04 PM
