Rear Brake Caliper Removal
68,000 MILES • 6 CYL • FWD • AUTOMATIC
DOCKILGORE
On the top caliper bolt there is a silver cap that appears to be covering the bolt head with a rubber nipple coming out of the center. The bottom caliper bolt comes off fine, but I can't get the "cap" off to place the socket wrench with any ease. I can see the bolt portion under the rubber "bridge". Is there a way of getting that off without doing damage to the caliper bolt or system.
Jul 29, 2008 at 12:54 PM
FEELGOOD71
  • 32 POSTS
the top cap DOES NOT come off
remove the bottom bolt then pull the caliper out from the bottom to replace the brake pads.
Here is a guide to help you see how to do the job.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
if your replacing the rotor also the whole bracket has to be removed just 2 more bolts.
Aug 15, 2020 at 4:07 AM
