2002 Buick Lesabre Power Window Mechanical Problem (right b
CDRAGOS
2002 Buick Lesabre
- power window cable system detached, possibly snagged between drum & metal (deduced from PopularMechanics.com lead)
- motor still works, cable winding / unwinding almost all the way, but no effect on window, which I can pull up and down
(all trim door trim off, observed movement with mirror while partner pushed button)
- the cable-pulley system seems quite complicated and inaccessible... can it be re-connected or just replaced by professional?
Thank you for any leads
-Cristian
Oct 28, 2008 at 5:34 AM
DENNYP
  • 1,824 POSTS
The window regulator assembly will need to be replaced.
Oct 31, 2008 at 4:32 AM
