2002 Buick Lesabre main window switch
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN PARKER
My front windows do not open . I have had this problem on and off for some time. One window will work for awhile then will not work then the other will work and now both are not working . How do I get at main switch to replace it or do I have some other problem?
Oct 22, 2010 at 11:25 AM
WRENCHTECH
  • 20,758 POSTS
The switch assembly snaps out of the door panel then unscrews from behind.
Oct 22, 2010 at 11:50 AM
JOHN PARKER
[quote:bc5eb0c5e6="john parker"]2002 Buick Lesabre 6 cyl Two Wheel Drive Automatic 65000 miles
My front windows do not open . I have had this problem on and off for some time. One window will work for awhile then will not work then the other will work and now both are not working . How do I get at main switch to replace it or do I have some other problem?[/quote:bc5eb0c5e6]
Oct 25, 2010 at 2:43 AM
WRENCHTECH
  • 20,758 POSTS
Your going to have to test the circuit following a wiring diagram AT THE TIME THE PROBLEM IS PRESENT to determine what the cause is. The main switch is a good possibilty.
Oct 25, 2010 at 2:49 AM
