2002 Buick Lesabre lights
82,000 MILES • 6 CYL • FWD • AUTOMATIC
RAY-K
has no interior lights,no trunk light,no back up lights,automatic door locks dont work
Apr 9, 2010 at 8:37 AM
INTERNETMECHANIC
  • 700 POSTS
Did you check any applicable fuse circuits?? When multiple circuits have a problem, I track one circuit, that will fix it, if all problems have a common issue? If no common issue, you fix one circuit at a time. If there is a communication problem between modules, I may not be able to fix from here. You can start by checking circuits at the interior lamps relay, check for voltage and ground.
Apr 9, 2010 at 9:05 AM
