2002 buick lasabre. Starter will not turn when the ignition switch is used. It clicks once and the engine trys to turn over. When I bypass the switch by using a remote strarter button attached to the solenoid, the engine turns over and if the key is in the run position the car will start. When the car is in park or neutral, I get the click, if in gear, no click. Assuming the park/neutral position switch is working properly. Removed the starter and had it bench checked, checked good. No codes or lights are showing. What do I check/replace next.
Sep 6, 2009 at 2:09 AM
