2002 Buick Lesabre fast idle
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUD VOISINET
2002 Buick LaSabre 3800; 92,000 mi. Car recently started idling fast (1800rpm vs. 800 normal.) It resets back to 800 by turning key off and restarting. But then usually goes back up to 1500-1800 RPM after a short time. Fault is not hard enough to apparently cause a permanant fault tag in the computer.
Which air/fuel sensor would likely cause this problem and why?
Sep 17, 2008 at 12:37 PM
  • 75,988 POSTS
Try the idle air control valve its job is to maintain the idle speed.
Sep 17, 2008 at 1:01 PM
BLACKOP555
  • 10,386 POSTS
i would be checking the IAC module as that is what changes the idle speed.
if not could be a faulty tps sensor.
high idle could be a vaccum leak buy 1000 more rpms is ALOT higher for a vaccum leak to cause.
Sep 17, 2008 at 1:03 PM
  • 75,988 POSTS
If a vehicle idles erratically and surges (idle speed is not steady and increases and decreases), the problem may be a buildup of carbon or fuel varnish deposits in the idle speed control valve (also called the idle air control valve or IAC valve). The cure for this condition is to clean the valve with some aerosol throttle cleaner or engine top cleaner.
Here's how to clean the IAC valve:
Disconnect the air intake ductwork from the throttle body.
Start the engine, then increase and hold the idle speed to 1,000 to 1,500 rpm.
Spray the throttle cleaner or engine cleaner into the throat of the throttle body, aiming for the idle air bypass port (usually located on the side or top of the throttle body opening). Give this area a good dose of cleaner (about 10 second's worth).
Turn the engine off to allow the cleaner to soak into the IAC passageway.
Wait about three minutes.
Restart the engine, rev and hold at 1,000 to 1,500 rpm, and repeat the cleaning process again.
Turn the engine off again, and reattach the air intake ductwork to the throttle body.
Start the engine and rev and hold to 1,500 to 2,000 rpm until no white smoke is coming out of the exhaust pipe.
If this fails to make any difference, you can remove the IAC valve from the throttle body and spray cleaner directly on the tip of the valve and/or into the ports in the throttle body. Let the cleaner soak awhile, repeat as needed, then reinstall the IAC valve, start the engine and run it at 1,500 to 2,000 rpm as before until no white smoke is seen in the exahust.
If the idle speed still surges after this, the IAC valve is defective and needs to be replaced.
Sep 17, 2008 at 2:54 PM
