2002 Buick Lesabre Engine missfiring
65,000 MILES • 6 CYL • FWD • AUTOMATIC
DJAMESON
What could make the car missfire on the #1 cylinder and the check engine comes on. Then if you shut the car off and restart the engine at a later date the engine run fine but the check engine light stays on. I took it to the dealer to get it checked and they check the injectors and change the #1 plug wire. It ran fine for 2 days and then started missing again. They can't figure it out. Could you shed any light on this problem
Nov 8, 2008 at 7:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
What code is the engine light showing?
Nov 8, 2008 at 8:08 AM
