2002 Buick Lesabre calipers
62,200 MILES • 6 CYL • FWD • AUTOMATIC
ED SIMBA
How do you remove top bolt on the rear calipers? Seems to have a plug covering access to the bolt.
Jul 30, 2009 at 6:47 AM
JMALECKI
  • 118 POSTS
that is not a bolt only a slide and the caliper should just slide off.
John
Aug 15, 2020 at 4:07 AM
ED SIMBA
John, thank you for your help. I'll take another try at this job.
ED SIMBA
No luck. Looks like a bolt to me. Will try to send pic.
JMALECKI
  • 118 POSTS
ok try to send a pic and we will see, but usually the one with the cap is only there as a slide it has a small hex head on it but that is only there if you have to replace it. commonly the caliper seazes to this slide you have to get some penatrating oil in there and work it around on the slide and try to slide the caliper off.
John
