2001 Buick Lesabre Service Engine CODES
JCN
Computer problem
2001 Buick Lesabre 6 cyl Two Wheel Drive Automatic
Codes indicated Catalytic Converter failure. I replaced the converter and the computer registers NO codes. Mechanic says computer is cycling through codes. Every time reset computer but service engine soon light comes on again. Mechanic disconnected computer then plugged back. No change. Light stays off for only 2-3 miles then returns showing NO codes. Please help.
Oct 23, 2010 at 10:05 AM
WRENCHTECH
  • 20,760 POSTS
You might want to try another scan tool just in case but if that is really true, it would mean that either there is an overcharging condition that doesn't set a code or the PCM itself is bad.
Oct 24, 2010 at 10:52 AM
