2001 Buick Lesabre P-Codes
150,000 MILES • 6 CYL • FWD • AUTOMATIC
MENMYGIRL
Recently my 2001 buick lesabre service engine light appear and when shift in gear it jerks, also while driving its doesn't seem to be shifing in gear and the RPM goes between 3 & 4. I took it to Autozone and these three warning codes appear: P1810, P0141, & P0135. Do you think it's something major wrong with the transmission? Help please
May 4, 2010 at 7:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC p0141 is indicating a faulty oxygen sensor, an easy and inexpensive repair
DTC p0135 also indicates a fault on the oxygen sensor circuit.
DTC P1810 is a transmission fault code which indicates the transmission fluid pressure manual valve position switch is malfunctioning. most likely fix for this is just replacing the switch.
May 4, 2010 at 4:16 PM
