2001 Buick Lesabre Heater problems
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BGEYER
The car was recently in a slight accident, side impact at drivers side front wheel. Ever since I got it back from the repair shop, it would not blow hot air when on heater.
Took it back to the shop, and they flushed radiator, and heater core. Both hoses from heater core are hot.
Still only blew slightly warm air. I did research online, and thought it could be heat actuator blend door. I replaced the unit, and now I have hot air, but only from floor vents. If I put the controller on vent, the air is not hot. If I put it on defrost, the air is only cold regardless of temp setting.
Nov 4, 2009 at 10:07 AM
BGEYER
Well, problem fixed. For anyone else out there, FYI. I bought a new actuator door, which didn't work. There was current going to the connector, but as I found out, the parts that I bought from various parts stores- O Reily, and Advance Auto Parts, the part that was listed as the correct part did not work because of the pin connection. Some of the parts had different pins missing. I had to finally wind up getting the part from a dealer.
Nov 8, 2009 at 12:29 AM
