2001 Buick Lesabre Dashboard Message
2001 BUICK LESABRE
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRCHRISV
The gauge display has a personalized message I'd like to delete or change. It's in the same 'window' where the fuel etc info is displayed
Jul 26, 2008 at 11:16 PM
MERLIN2021
  • 17,250 POSTS
DRIVER INFORMATION CENTER PERSONALIZATION PROGRAMMING
1. Turn ignition switch to RUN position. Ensure transmission is in Park. Select DRIVER ID 1 or DRIVER ID 2 by pressing UNLOCK button on Remote Keyless Entry (RKE) transmitter or appropriate memory seat control.
2. Press and hold ENG/MET button for 5 seconds. WELCOME TO BUICK OPTION FEATURE will be displayed on Driver Information Center (DIC).
3. Select DRIVER ID 1 or DRIVER ID 2 by pressing ENG/MET button to toggle between selections. Press RESET to choose a current selection.
4. Each feature that can be personalized will appear on DIC display. Once a selection is made for a feature, DIC will advance to next feature.
5. To exit selection mode without moving through each personalization feature, press a different button on DIC or turn ignition switch to OFF position. Selections will be retained.
Jul 26, 2008 at 11:35 PM
