2001 Buick Lesabre Belt tensioner
120,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVEO453
the belt tensioer broke and was wondering how hard it is to replace with new one?
Feb 1, 2010 at 8:46 AM
  • 75,988 POSTS
2001 Buick LeSabre V6-3.8L VIN K Removal Procedure
https://images.2carpros.com/forum/automotive_pictures/12900_dbt1_1.gif
1.Drain the cooling system. 2.Remove the generator. 3.Remove the heater hoses from the drive belt tensioner fittings.
https://images.2carpros.com/forum/automotive_pictures/12900_dbt2_1.gif
4.Remove the drive belt tensioner bolts. 5.Remove the drive belt tensioner from the engine. Installation Procedure
https://images.2carpros.com/forum/automotive_pictures/12900_dbt3_1.gif
1.Install the drive belt tensioner to the engine. Notice: Refer to Fastener Notice in Service Precautions. 2.Install the drive belt tensioner bolts. *Tighten the drive belt tensioner bolts to 50 Nm (37 ft. lbs.) .
https://images.2carpros.com/forum/automotive_pictures/12900_dbt4_1.gif
3.Connect the heater hoses to the drive belt tensioner fittings. 4.Install the generator. 5.Fill the cooling system.
Feb 1, 2010 at 11:57 AM
