2001 Buick Lesabre airbag suspension
TWIGGIE27
Suspension problem
2001 Buick Lesabre 6 cyl Front Wheel Drive 134000 miles
i wanted to know if the 2001 lesabre really have airbag suspension and if so, when they go out would it make the car run rough? also, could the rubber from the bags cause the tires to wobble? what should i do and will it be expensive?
May 23, 2008 at 6:49 PM
GJONES_60
I am assuming that the 2001 is like by 2000, but it has air shocks not air bags. The shocks run off a compressor located near the rear of the car. If the shocks were worn out, it would cause the rear end to me "bouncy", which could cause a rough ride. The shocks are expensive when compared to normal shocks, but not outrageous about $60-80 each.
May 26, 2008 at 1:38 PM
