2000 Buick Lesabre transmission shifts rough intermittently
2000 BUICK LESABRE
18,700 MILES • 6 CYL • 2WD • AUTOMATIC
DABUNNY
Hi
I would like your help in solving the following.
Intermittently when I'm driving my 2000 Buick Lesabre, when it shifts gears, it is really rough. I've checked my transmission, had the transmission oil changed and can't seem to figure out what the prblm is. It happens irregularly. I was thinking it was due to bad gas or dirt getting trapped in the engine filter. It seems to correct itself once I add a bottle of gas line antifreeze also thinking humidity in the gas or turning it off and letting it sit. Also, I've tried with filling the tank full and this also seems to correct the prblm. I just also had my oil changed today and was advsd that all is well, no leaks.
Could it be an electrical prblm, ie: bad spark plugs or wiring?
Any help in trying to figure this out would be greatly appreciated it.
Thank You
Mar 31, 2008 at 7:33 PM
DENNYP
  • 1,824 POSTS
It probably has a p1811 code. You will need a pressure control soleniod an pressure range switch.
Apr 1, 2008 at 7:19 AM
