2000 Buick Lesabre Testing AC
JPARKER1972
Air Conditioning problem
2000 Buick Lesabre 250000 miles
What should the PSI (high and low) be on this car? I'm pretty sure something's not right since the low pressure pegged as far as it could go. The high side registered about 200 PSI. Any ideas what's going on with it? The AC is working fine, but there's a squeal that seems to be coming from the pump.
Jul 19, 2008 at 3:35 PM
DENNYP
  • 1,824 POSTS
What are the high and low side pressures with the engine running? You could have a bad belt or compressor.
Jul 23, 2008 at 3:58 PM
