2000 Buick Lesabre strong smell
14,600 MILES • 6 CYL • 2WD • AUTOMATIC
DAGMAR TOUCHTON
I have a strong smell inside the auto and outside. not always but a lot of the time. racing the engine in nuetral seems to help some.
Mar 15, 2010 at 12:13 PM
SERVICE WRITER
  • 9,123 POSTS
Would you say it might be raw fuel smell? Moldy? Exhaust -like?....I can't quite get the whiff from here...
Mar 15, 2010 at 12:28 PM
DAGMAR TOUCHTON
gasoline or oil smell
Mar 15, 2010 at 12:43 PM
SERVICE WRITER
  • 9,123 POSTS
IT would be best to get the car up in the air and get a look at the fuel lines. They can get pretty rotted and allow fuel to seap through the line and cause a raw fuel smell. Typical areas are along the frame rail where othe lines are grouped and fastened together and also from the top of the tank where the sending unit is.
By racing the engine, fuel suction becomes stronger and circulates the fuel enough to reduce the leakage.
I would not put this off as the vapors are explosive. We had 2 shops in the last 2 years blow up from fuel vapors ignitiing.
Mar 15, 2010 at 10:21 PM
