Firing order?
112,000 MILES • 6 CYL • FWD • AUTOMATIC
JC5667
i was at a diagnostic center & they told me i had to change the coil for spark plug #4. ea coil has 2 plug wires on it, both on the right side! without getting under the car & tracing the wire, which coil is it? top, middle or bottom?
Mar 25, 2008 at 8:12 AM
  • 75,988 POSTS
See below pick your type
https://images.2carpros.com/forum/automotive_pictures/12900_fo1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_fo2_1.jpg
Mar 25, 2008 at 9:23 AM
PHILLIEGROOVE
1993 Buick Lesabre 6 cyl
what is the firing order. thank you
Nov 14, 2020 at 9:00 AM (Merged)
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_lesabre_1.jpg
Hello, I came across the above info.
SP00KY.1979
I need the firing order and which cylinder is which
INTERNETMECHANIC
  • 700 POSTS
Not sure which engine you have? This info is for the 3.1 L engine.
https://images.2carpros.com/forum/automotive_pictures/512072_buick_lesabre_31_firing_order_1.jpg
BRANDON WIGGINS
What is the firing order and cylinder location of 3800 92 lesabre
WRENCHTECH
  • 20,760 POSTS
Type one system http://i1198.photobucket.com/albums/aa448/Wrenchtech/92717857.jpg.gif Type two system https://www.2carpros.com/images/external/92717856.jpg.gif
TTEOVD
Engine Performance problem 6 cyl Two Wheel Drive Automatic 120785 miles
I need the firing order for my car can you please help me?
MERLIN2021
  • 17,250 POSTS
Depends which 6 you have?
https://images.2carpros.com/forum/automotive_pictures/62217_FO_6.jpg
This is for 3.1 and 3.4
https://images.2carpros.com/forum/automotive_pictures/62217_FO33_1.jpg
This is 3.3
https://images.2carpros.com/forum/automotive_pictures/62217_FO38_1.jpg
This is 3.8....
GR8NESS
1991 Buick Lesabre 6 cyl Two Wheel Drive Automatic
can you provide the diagram for the plugs and wires to the coil pack for a 91 buick lesabre? I changed the coil pack, and modulator and the car is not running correctly. it is constantly cutting of, and sputtering, which it did not do prior. Both the modulator and coil pack are new, not used.
WRENCHTECH
  • 20,760 POSTS
https://images.2carpros.com/forum/automotive_pictures/561653_Firing_order_91_38_1.jpg
Nov 14, 2020 at 9:01 AM (Merged)
