2000 Buick Lesabre oil pressure reading
KUCH
Engine Mechanical problem
2000 Buick Lesabre 6 cyl Two Wheel Drive Automatic 128,xx miles
gauge reading is constant 129 - oil filter gasket is still intact after several hundred miles
Mar 20, 2009 at 9:34 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could be the oil pump or engine bearings/restriction in flow
Mar 20, 2009 at 10:18 AM
