2000 Buick Lesabre hot/cold
176,000 MILES • 6 CYL • FWD • AUTOMATIC
TIPPSTER225
i have a 2000 buick lesabre when i turn on the a/c it blows hot on the passanger side and cold on the driver i tried charging it but it still does the same thing what can be problem be
Mar 11, 2010 at 4:06 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. I'd have to check hvac codes, if there are any? I believe there is a temp sensor on each side of dash. I'm not saying there is anything wrong with the sensor. I'd have to go through the diagnostic checks. Might be an actuator that directs airflow, that isn't working like it should?
Mar 12, 2010 at 1:30 AM
