2000 Buick Lesabre EXCESSIVE SHAKING WHILE PUSHING BRAKE PE
PARVOPITS
  • 9 POSTS
Brakes problem
2000 Buick Lesabre 6 cyl Front Wheel Drive Automatic 110K miles
OTHER THAN ROTORS WHAT ELSE CAUSES SHAKING OF BRAKE PEDAL WHEN STOPING.
Mar 5, 2008 at 5:38 AM
MERLIN2021
  • 17,250 POSTS
Worn front end parts, and shifted steel belts in the tires...loose wheels?
Mar 5, 2008 at 5:39 AM
PARVOPITS
  • 9 POSTS
I CHANGED THE HUB ASSEMBLY, CAN U LIST NAMES OF SOME OF THE WORN FRONT END PARTS THAT NORMALLY NEED TO BE REPLACED??
THANKS
Mar 5, 2008 at 5:51 AM
MERLIN2021
  • 17,250 POSTS
Did the shaking start before or after you replaced the hub? Did you use a torque wrench to tighten, the axle nut? and the lug nuts? I ask because you may have warped the rotor during this process, Front end parts are checked for play, any alignment or tire shop can do this if you need advice...
Mar 5, 2008 at 6:02 AM
PARVOPITS
  • 9 POSTS
I BELIVE THE SHAKING STARTED AFTER THE HUB ASSEMBLY WAS REPLACED, THE HUB ASSEMBLY WAS REPLACED BECAUSE WHEN PURCHASED NEW TIRES. THE MECHANIC SHOWED ME THE PLAY OR SHAKE THE WHEELS HAD AFTER TIGHTENING THE WHEELS BACK ON AFTER REPLACING THE TIRES. AND THEN AFTER THE HUB ASSEMBLY WAS CHANGED ON BOTH SIDES THATS WHEN THE SHAKING BEGAIN TO BE ACCESIVE. AND I DONT BELIEVE A TORQUE WRENCH WAS USED. I ALSO HAD A UNCERTIFIED MECHANIC DO THE JOB, SO IM ON MY WAY 2 HAVE AN ALIGNMENT SHOP TEST DRIVE AND TELL ME WHAT THEY THINK.
ANY OTHER ADVISE????
FROM YOU BEFORE I GO WILL BE APPRECIATED.
THANKS A MILLION
Mar 5, 2008 at 6:19 AM
MERLIN2021
  • 17,250 POSTS
If an air impact was used to put the tires back on, or to tighten the axle nut, Either the rotor was warped by excessive force applied when the lug nuts were improperly thightened, or the new hub bearing can be damaged when the axle nut is nut torqued to proper specs! Or they blew the call on what part needed to be replaced, was there any growling noise after 35 mph?
Mar 5, 2008 at 6:26 AM
PARVOPITS
  • 9 POSTS
NO GROWLING, BUT A LIL SHAKING @ 65MPH BUT NO SHAKING UNDER OR OVER 65MPH
Mar 5, 2008 at 6:50 AM
PARVOPITS
  • 9 POSTS
ONLY SHAKES @ 65MPH UNDER UNDER ONLY WHEN BRAKES ARE APPLIED
Mar 5, 2008 at 6:53 AM
MERLIN2021
  • 17,250 POSTS
Sounds like a warped rotor..
Mar 5, 2008 at 7:01 AM
PARVOPITS
  • 9 POSTS
THANKS
Mar 5, 2008 at 7:03 AM
