2000 Buick Lesabre Car shakes under mild acceleration aroun
20,000 MILES • 6 CYL • FWD • AUTOMATIC
LARRY MARK
Abrupt onset of condition, new tires, balanced and check rotated twice by dealer, new hubs and bearings within last 4 months, new brakes, disks and pads. checked, tie rod ends, CV shafts for tightness, Struts and top bearings, all tight.
Shake starts as you accelerate to 50 KPH. worsens as you level off and maintain speed. Same under cruise and with traction control off. When you release the throttle, the problem goes away and resorts to a small shake.
Oct 11, 2009 at 5:19 AM
LOUT5369
  • 217 POSTS
Sounds like the inner CV joint is bad on the axle,the outter will make noise on turns when bad,the inner vibrates when bad.
Oct 12, 2009 at 11:35 PM
