2000 Buick Lesabre CAN'T GET A COMPUTER READING
81,000 MILES • 6 CYL • FWD • AUTOMATIC
MACKAE
SERVICE ENGINE LIGHT CAME ON. TOOK IT TO HAVE CODE READ BUT GUY SAID FUSE WAS BLOWN AND COULDN'T READ IT. PULLED ALL THE SMALL FUSES AND THEY ALL LOOK GOOD. ALSO INTERIOR LIGHTS DO NOT COME ON WHEN DOOR IS OPENED BUT MAP LIGHTS WORK WHEN YOU PUSH THEM ON
Jun 8, 2010 at 10:26 AM
SATURNTECH9
  • 30,868 POSTS
First of all thank you very much for your donation.Do you have a limited or custom model?I was looking at the limited wire diagram and look's like if you have that model i would check your ALDL fuse 10 amp located in your rear fuse box.Let me know which model you have so i can get you the correct information.
Jun 8, 2010 at 10:55 AM
MACKAE
it is a custom series.
Jun 8, 2010 at 11:39 AM
SATURNTECH9
  • 30,868 POSTS
I emailed you the wire diagram for the obd2 connector and circuit's.Also emailed you the rear fuse box legend's so you know what fuse's are what.Also emailed you where and what it look's like.The rear fuse box is located under the rear seat look in the rear fuse box legend part1 looks like you want fuse number 4 which is your ALDL that's the one that send's power to where you read your code's.Also check your other fuse's while your in there let me know what you find.
Jun 8, 2010 at 12:25 PM
