How to change a fuel pump?
126,000 MILES • 6 CYL • FWD • AUTOMATIC
17SCOTTJEN
how to change a fuel pump om a 2000 buick lesabre
Oct 25, 2010 at 3:02 AM
SATURNTECH9
  • 30,869 POSTS
REMOVAL PROCEDURE
CAUTION:
* Gasoline or gasoline vapors are highly flammable. A fire could occur if an ignition source is present. Never drain or store gasoline or diesel fuel in an open container, due to the possibility of fire or explosion. Have a dry chemical (Class B) fire extinguisher nearby.
* Provide proper ventilation when working with fuel in enclosed areas where fuel vapors can collect. The lack of adequate ventilation may result in personal injury.
* Always wear safety goggles when working with fuel in order to protect the eyes from fuel splash.
* Fuel Vapors can collect while servicing fuel system parts in enclosed areas such as a trunk. To reduce the risk of fire and increased exposure to vapors:
* Use forced air ventilation such as a fan set outside of the trunk.
* Plug or cap any fuel system openings in order to reduce fuel vapor formation.
* Clean up any spilled fuel immediately.
* Avoid sparks and any source of ignition.
* Use signs to alert others in the work area that fuel system work is in process .
NOTE:
* Clean all of the following areas before performing any disconnections in order to avoid possible contamination in the system:
* The fuel pipe connections
* The hose connections
* The areas surrounding the connections
* Do not handle the fuel sender assembly by the fuel pipes. The amount of leverage generated by handling the fuel pipes could damage the joints.
* Replace the fuel sender O-rings when re-installing the fuel sender in order to avoid damage to the fuel sender assembly
1. Relieve the fuel system fuel pressure. Refer to Fuel Pressure Release.
2. Drain the fuel tank (1) to at least 3/4 full. Refer to Fuel Tank Draining Procedure.
3. Remove the spare tire cover, the jack, and the spare tire.
CAUTION: Remove the rear compartment floor trim to provide technician contact with the vehicle's metal surfaces Failure to remove the rear compartment floor trim may cause a static electricity discharge to ignite any fuel vapor resulting in personal injury and vehicle damage .
NOTE: Remove the rear compartment floor trim to avoid damage from fuel spillage.
4. Remove the Compartment Trim Panel Replacement - Rear (1).
5. Remove the fuel sender access panel (1).
6. Clean the fuel pipe connections, the hose connections, and all of the areas surrounding the connections before disconnecting the connections in order to avoid possible contamination of the fuel system.
7. Remove the quick-connect fittings at the fuel sender assembly.
8. Remove the electrical connector at the fuel sender.
9. Remove the electrical connector at the fuel tank pressure sensor.
IMPORTANT:
* The modular fuel sender will spring-up when the retaining cam is removed.
* When removing the modular fuel sender assembly from the fuel tank, the reservoir bucket on the fuel sender assembly is full of fuel. The fuel sender assembly must be tipped slightly during removal in order to avoid damage to the float. Place any remaining fuel into an approved container once the fuel sender assembly is removed from the tank.
10. Remove the fuel sender retaining ring using the J 39675 Fuel Sender Spanner Wrench.
11. Remove the fuel sender assembly retaining cam, using the J 39675 Fuel Sender Spanner Wrench.
12. Remove the fuel sender assembly and the O-ring from the fuel tank.
13. Discard the fuel sender assembly O-ring.
14. Clean and inspect the O-ring sealing surfaces on the fuel sender assembly.
INSTALLATION PROCEDURE
NOTE: Always re-attach the fuel lines and fuel filter with all original type fasteners and hardware.
Do not repair sections of fuel pipes.
IMPORTANT: Always replace the fuel sender O-ring when the reinstalling the fuel sender assembly.
1. Position the new O-ring for the fuel sender assembly on the fuel tank.
IMPORTANT: Care should be taken not to fold over or twist the fuel pump strainer when installing the fuel sender assembly, as this will restrict fuel flow. Also, assure that the fuel pump strainer does not block full travel of float arm.
2. Assemble the fuel sender assembly and the retainer cam using the J 39675 Fuel Sender Spanner Wrench.
IMPORTANT: Care should be taken not to fold over or twist the fuel pump strainer (4) when installing the fuel sender assembly, as this will restrict fuel flow. Also, assure that the fuel pump strainer does not block full travel of float arm.
3. Install the fuel sender assembly and the fuel sender assembly retainer cam using the J 39765 Fuel Sender Spanner Wrench.
4. Install the quick-connect fittings at the fuel sender assembly. Refer to Quick Connect Fitting(s) Service (Plastic Collar).
5. Connect the electrical connector at the fuel tank pressure sensor.
6. Connect the electrical connector at the fuel sender assembly.
7. Connect the negative battery cable.
8. Perform the following procedure to inspect for leaks:
8.1. Turn the ignition switch On for 2 seconds .
8.2. Turn the ignition switch Off for 10 seconds .
8.3. Turn the ignition switch On.
8.4. Check for fuel leaks.
NOTE: Refer to Fastener Notice in Service Precautions.
9. Install the fuel sender access panel.
Tighten
Tighten the bolts to 2 Nm (18 lb in) .
10. Install the rear compartment trim panel (1).
11. Install the spare tire, the jack, and the spare tire cover.
12. Add fuel to the fuel tank.
13. Install the fuel tank filler cap.
There you go.
Oct 25, 2010 at 3:15 AM
