1999 Buick Lesabre water leaks
1999 BUICK LESABRE
25,000 MILES • 6 CYL • FWD • AUTOMATIC
FGVJRGOPIWUT
Water is leaking around the driver side door and into the floorboard causing a smell and mold. i have put a new seal around the door and put polyurethane to and it still leaks. i have took the interior completely out. what do i do?
Feb 23, 2010 at 1:56 AM
DENNYP
  • 1,824 POSTS
water leaks can be very difficult to find. You will need to rig up a stand that can hold a water hose. Direct the water to the general area of the leak. Get in the car and look for any water coming in. If you have a sunroof, blow compressed air through the drain tubes to make sure they are clear of obstructions.
Feb 24, 2010 at 2:56 PM
