1999 Buick Lesabre Spark plug replacement
TOMWEST2
Electrical problem
1999 Buick Lesabre 6 cyl Wheel Drive Type unknown 60000 miles
How do you replace the spark plugs on a 1999 Buick LeSabre? Every pair seems to be mounted through a square-shaped part. Do I unscrew the square part and pull it off of the spark plugs? Will it be a simple unscrewing of the spark plugs after that?
Mar 31, 2008 at 5:18 AM
DENNYP
  • 1,824 POSTS
pull the wire from the plug and unscrew the spark plug. It will take a 5/8 spark plug socket.
Mar 31, 2008 at 5:34 AM
