1999 Buick Lesabre replace RH mirror
118,000 MILES • 6 CYL • FWD • AUTOMATIC
VICLIS
99 buick lesabre, How do I replace the right side power mirror? How do I remover the door panel to get to it?
Nov 13, 2009 at 11:57 PM
  • 110,251 POSTS
There are a few screws that will need removed. Remove the arm rest, and check for plug covers on the panel that may have a screw under them. Next, there are clips between the panel and the door that hold it in place. Carefully pry them apart from the door.
Once it's removed, the mirror is held in place with two screws.
Nov 23, 2009 at 1:48 AM
