1999 Buick Lesabre fuel pump
B-RADFORD
Engine Performance problem
1999 Buick Lesabre 6 cyl Automatic 123000 miles
Recently replaced the fuel pump, strainer and filter.
Pump will not pump fuel.
Any ideas?
Jul 1, 2010 at 10:37 AM
SATURNTECH9
  • 30,869 POSTS
I would see if you have power and ground to the fuel pump when your cranking the engine.Also is the security light on or flashing?Do you have any code's?Can you rent a code scanner to see if you have any code's?That might point us in the right direction.
Jul 1, 2010 at 10:50 AM
