1999 Buick Lesabre engine flooding
MIKEG87
Engine Mechanical problem
1999 Buick Lesabre 6 cyl Front Wheel Drive Automatic
When i got the car it was running hot and the upper intake was shot. i replaced the upper intake the lower intake all gaskets. After putting everything back together i go to turn the engine over and it fills with gas. The fuel pressure is around 45-50 psi. The starter has replaced the plugs aswell. Any idea on what is causeing it?
Thank You
Mar 23, 2009 at 10:22 AM
BILLYMAC
  • 2,204 POSTS
i would suspect first coolant temp sensor. next a stuck injector .
Mar 30, 2009 at 1:52 AM
