1998 Buick Lesabre Very recent problem arose after using Fu
1998 BUICK LESABRE
154,000 MILES • 6 CYL • 2WD • AUTOMATIC
PETERPIPER
I recently added STP Super Concentrated Fuel Injection Cleaner to my gas tank. The cleaner worked - the variable RPMs at idle ceased and became much smoother. However, at the same time (about 30 minutes of driving), the engine began to vibrate, which I was able to feel through the steering wheel. Also, the engine light began to blink, indicating a misfiring or something else. I have just about used up the gas that included the injection cleaner, so the injection cleaner will soon be completely out of the gas system. So far, the vibrating engine, which occurs more strongly when the car in in drive or reverse (and is less obvious when in park or neutral), has not relaxed at all. I am worried that my use of the fuel injection cleaner, while fixing one problem, started another. Should I be concerned? What is the problem and what is causing it?
Thanks for your help
Nov 17, 2009 at 8:31 AM
SERVICE WRITER
  • 9,123 POSTS
You have a misfire goiing on. The missing cylinders are creating a rich condtion that is affecting the converter.
Don't drive it with the cel flashing.
The cleaner and the misfire may or may not be related. At 154,000 anything is possible. You need to have the codes read to start troubleshooting this. Get them and post them.
Nov 19, 2009 at 9:28 PM
