After changing the battery I no longer get air out the dash vents. I have windshield and floor air. I can redirect it to either of those locations or both at once. I dropped the glove box door and nothing moves there. I also checked, there is vacuum present. I have also removed fuse 9C for a reset and it's no different. It is automatic climate control.
I do get a light but no noise that I can hear other than the fan running. The vent led works as well as the others. If I turn on the recirculate button it lights but air comes from the windshield vents and the floor. It blows cold air also.
The person I purchased the car from said this started when she replaced the battery but I have been through all that procedure and nothing works. Should I be able to move the control arm behind the glove box manually?
I do have battery voltage between those two wires. The programmer is bad is it something I can replace and do you know where to find it for the best price?
Thanks in advance for your help.
Jan 17, 2009 at 1:21 AM
